I am using a kflop,kstep,and kconnect board and am testing a proximity switch coming into 1040 on the connect board. this is a normally closed switch and I have set it up in the positive direction for the x axis.
I set the axis to watch the limit and stop when low. The action is set to disallow to drive into limit. I am testing using kmotion cnc and when I make the prox when moving positive it stops the machine. It will not stop when running negative like it is supposed to.
What needs to happen to allow me to go negative away from the limit. I can init the system to get movement but then My zeros are lost.
